You could try running: rpm -Va --nofiles --nodigest
    سلام من php7 رو نصب کردم الان میخوام phpmyadmin نصب کنم، موقع نصبش خطای Error: Package: phpMyAdmin-4.4.15.10-3.el7.noarch (epel) رو میده. چطور میتونم این مشکل رو بطرف کنم؟
    ErrorPackagephpMyAdmin-4.4.15.10-3.el7.noarch (epel)
    Requiresphp-zip
               Available
    php-common-5.4.16-46.el7.x86_64 (base)
    php-zip
               Available
    php-pecl-zip-1.15.3-1.el7.remi.7.1.x86_64 (remi-php71)
    php-zip 1:1.15.3-1.el7.remi.7.1
               Available
    php-pecl-zip-1.15.3-4.el7.remi.7.3.x86_64 (remi-php73)
    php-zip 1:1.15.3-4.el7.remi.7.3
               Available
    php-pecl-zip-1.15.4-1.el7.remi.7.1.x86_64 (remi-php71)
    php-zip 1:1.15.4-1.el7.remi.7.1
               Available
    php-pecl-zip-1.15.4-1.el7.remi.7.3.x86_64 (remi-php73)
    php-zip 1:1.15.4-1.el7.remi.7.3
               Available
    php55w-common-5.5.38-1.w7.x86_64 (webtatic)
    php-zip
               Available
    php56w-common-5.6.39-1.w7.x86_64 (webtatic)
    php-zip
               Available
    php56w-common-5.6.40-1.w7.x86_64 (webtatic)
    php-zip
               Available
    php70w-common-7.0.33-1.w7.x86_64 (webtatic)
    php-zip
               Available
    php71w-common-7.1.25-1.w7.x86_64 (webtatic)
    php-zip
               Available
    php71w-common-7.1.26-1.w7.x86_64 (webtatic)
    php-zip
               Available
    php72w-common-7.2.13-1.w7.x86_64 (webtatic)
    php-zip
               Available
    php72w-common-7.2.14-1.w7.x86_64 (webtatic)
    php-zip
               Installed
    php-common-7.3.2-1.el7.remi.x86_64 (@remi-php73)
    Not found
               Available
    php-common-7.1.25-2.el7.remi.x86_64 (remi-php71)
    Not found
               Available
    php-common-7.1.26-1.el7.remi.x86_64 (remi-php71)
    Not found
               Available
    php-common-7.3.1-1.el7.remi.x86_64 (remi-php73)
    Not found
     You could
    try using --skip-broken to work around the problem
     You could
    try runningrpm -Va --nofiles --nodigest
    ریپازیتوری remi رو نصب کردید؟
